bitbaltic
I don't think you've actually read this thread, have you?
+1
I have tried every combination of wires and nothing has worked including what you said on your site (which I found before posting on here). The problem is- Lowrance is very confusing. The simple 'Connect black, to TX+ and Ground to negative and it all works fine- simply does not work on the Lowrance unit. I posted to see what other people thought and clearly others have been confused by these units as well.
The really interesting question is how can Lowrance say the plotter is AIS compatible if it doesn't have NMEA input? Sale of Goods Act, anyone?
Wasn't the AIS2's idea of NMEA a bit suspect? Hence the AIS3 and the opportunity to upgrade the AIS2 with a new chip. .
Whether that's a specific fault or a generic one I can't say for certain but I suspect the latter
I was assuming you were connecting to a plotter that could actually receive data
BigStu - you need a plotter with an RX+ connection not a TX+
And your point is....? Or do you just like rubbing people's noses in it after they have apologised? I recommend you try a Transactional Analysis exercise, you might learn something quite interesting.While vociferously asserting that you had read the posts where people had already identified that that's not the case...
Hey ho- listen, we know the answer now, so let's just leave the off topic digs alone people!
Nasa, innit?
Indeed. The Amstrad of the marine equipment world (but with, it must be said, infinitely better customer support that Alan Sugar ever delivered)
Buyers of Nasa kit always say "oh, but the customer service is very good", rather than wondering why the stuff broke in the first place.
Well true but at least the customer service is good
Just think what they might achieve if they put a fraction of that effort into design, development and quality control.
Much the same as Amstrad would have achieved, significantly higher manufacturing costs and a product that was no longer priced well below anything else on the market. That's their USP and they've been very successful by sticking to it
