[2574]
i think we are all familiar with the AIS triangles that appear on the AIS or chart plotter screen to indicate the position of an AIS equipped vessel. The triangle indicates the direction of travel of the vessel via the "point" of the triangle pointing in the direction of COG. If one has predicted heading switched on then a longer line indicates extended COG.
However, whilst sailing on Sunday I noticed that the AIS signal arrow of an eastbound passenger ferry indicated a COG which was 180deg opposed to her direction of travel, it indicated a Westbound COG. Now maybe this was because this was a "both ended" ferry and as far as the AIS was concerned it was being driven backwards.
I checked the COG being reported in the AIS details screen for the vessel which was correctly reporting the COG as heading east. Maybe this apparent contradiction is always the case with both ended ferries but it was a bit of a surprise to me and could be a significant factor in poor visibility. One's own radar and AIS arrow would be in conflict or, if one was relying upon AIS only it could be much more serious. One to note - don't absolutely always assume that the indicated direction of travel is correct. I didn't check whether the CPA was also screwed, I should have done but didn't think of it.
