Robin
If you're a mile off, in fog, on a collision course, you are 2 minutes away from that collision. You haven't a prayer with such tactics. Commercial shipping will not slow down and comply with the col regs, period ....
You are correct of course for a ship doing the kind of speed that the one which hit Wahkuna was, around 27kts I believe. But not many do that speed fortunately, as will be seen from AIS Live data. But the difficulty of identifying the collision risk is still the same, the data is gathered differently but the plotted results are no different, how can they be? In clear vis it is still very difficult to determine if a ship closing at an acute angle will clear or not, the bearings start to change only once in closer range. This problem is no different in zero vis, only that now you have to trust to instruments and your ability to use them and much depends on what else is close by or coming up fast as well. On occasion we have used the 'stop' or rather 'almost stop' option (to keep steerage and a constant heading on the screen), but only when at a greater distance. We have also chosen to cross at nearer 90 degs if it is very busy, then go back on course between lanes and see if the same tactic is needed for the next one, although this is a bigger detour than it might seem.
The actual CPA isn't the whole solution either, I don't know how to explain it especially in radar terms but in clear vis a ship that I cross a mile ahead of quite safely, might have a CPA of only 1/4 ml as he passes down one side at the acute angle we talked about. I would not be happy about a CPA of just 1/4ml, yet that ship was cleared effectively by 1 full mile, big difference!
What is really needed is to get out of this cold damp foggy corner of the world and sail where radar is the name of the barman's dog!
