Airmar P79 Issue
Dino
27 Apr 2009
Ireland
Hi,
I’m away cruising at the moment and my depth sounder has stopped working. It’s a Raymarine i40 Depth with an Airmar P79 transducer. I have replaced the connectors on the wires and occasionally I get an oddball reading of 4.1ft and then it flashes for a bit and then I get three dashes.
I just inspected the transducer in the hull. It’s an in-hull unit with a greenish blue liquid in it. The liquid looks dirty and it looks to be low.
Is there anything I can replace this liquid with to see if I can get it working again?
Boathook
5 Oct 2001
Surrey & boat in Dorset.
I think that I filled my P79 up with antifreeze. Can't remember the type recommended as manual's are down on the boat. If the liquid is dirty that could affect performance along with a low level.
PaulRainbow
16 May 2016
Suffolk
Hi,
As a temp fix, any cooking oil will do. If it works, change it for antifreeze before the cooking oil goes rancid.
Dino
27 Apr 2009
Ireland
Thanks folks, I had antifreeze onboard so I cleaned out the old gunge thoroughly and cleaned everything. Put Vaseline on the o ring and put around 75ml of antifreeze into the bath. Refitted the top and hey presto… we have depth again.
Delighted to be able to repair it on the go.
Moonbeam
15 Mar 2010
South Devon
Good to hear you have it fixed... just for info...Our P79 worked with just being stuck to a nice bed of window putty/plumbers mate on the inside of the hull. It was meant to be temporary install until I got the oil bath sorted, but it worked so well I left it... it was still going strong after 12 years when the boat was sold.
graham
It's obviously true that anti-freeze doesn't freeze, but the main benefit over oil is that it doesn't go rancid.
And that may explain the faint rotting vegetable type smell I have recently noticed in one of our boats lockers which has an oil bath depth transducer with vegetable oil in it.
PaulRainbow
16 May 2016
Suffolk
The transducer for our fishfinder is fastened to the inside of the hull with about half a tube of silicone sealant.
Which is against the manufacturers fitting instructions. Foft sealants between the transducer face and the hull absorb some of the sonar signals and give inaccurate readings.
