aircraft maintenance
byron
RIP
UK -Berks
Never let it be said that ground crews and engineers lack a sense
of humour. Here are some actual logged maintenance complaints,
and the corrective action recorded by mechanics.
P stands for the problem the pilots entered in the log, and S
stands for the corrective action taken by the mechanics).
P: Left inside main tire almost needs replacement.
S: Almost replaced left inside main tire.
P: Test flight OK, except autoland very rough.
S: Autoland not installed on this aircraft.
P: Something loose in cockpit.
S: Something tightened in cockpit.
P: Dead bugs on windshield.
S: Live bugs on backorder.
P: Autopilot in altitude-hold mode produces a 200-fpm descent.
S: Cannot reproduce problem on ground.
P: Evidence of leak on right main landing gear.
S: Evidence removed.
P: DME volume unbelievably loud.
S: DME volume set to more believable level.
P: Friction locks cause throttle levers to stick.
S: That's what they're there for!
P: IFF inoperative.
S: IFF always inoperative in OFF mode.
P: Suspected crack in windscreen.
S: Suspect you're right.
P: Number 3 engine missing. (note: this was for a piston-engined
airplane; the pilot meant the engine was not running smoothly)
S: Engine found on right wing after brief search.
P: Aircraft handles funny.
S: Aircraft warned to straighten up, fly right, and be serious.
P: Radar hums.
S: Reprogrammed radar with words.
P: Mouse in cockpit.
S: Cat installed
<font color=red> ô¿ô</font color=red>
<A target="_blank" HREF=http://www.freeware.mcmail.com/435.htm>http://www.freeware.mcmail.com/435.htm</A>[/b]
