steved
My boat has 2 x 200 litre fuel tanks that both feed into one prefilter.
The intake and return lines can all be individually isolated at the filter, and I normally run the engine using the feed and return from one tank only, and then swap tanks every so often.
Took the boat out yesterday for a run, and when throttle was increased the revs built up and then power dropped off, initially I was thinking that the filters could be clogged up. However, the glass filter bowl was showing bubbles being drawn in from somewhere. Switched over to the other tank and the bubbles disappeared and the engine ran fine right up to 3500 rpm.
How do you think the air is getting into fuel lines? My initiall thought is to check and tighten all the joints, but if air is getting in I would have thought that there would be some leakage / diesel smell.
Any thoughts?
Steve
Any thoughts?
Steve
