bluedragon
Could do with some opinions and advice. We've just had an upgraded primary filter fitted (Racor 500FG) in a nicely accessible position in a locker, just above the fuel tank. The outlet of this goes as usual to the lift pump and then engine filter.
Since fitting the new filter last week, the engine speed has become erratic, especially in the 1500-3000rpm range. After a short while at constant throttle the revs begin to fall away and won't always pick up on increasing the throttle lever setting, though shortly afterwards the speed will increase again of its own accord. The engine starts immediately and runs OK on tickover and low rpm. It's as though the engine is struggling to get fuel perhaps because of a blockage, then clears itself, but the lift pump primes the system very easily and all filter elements are new and the fuel is clean so this seems unlikely. We can only assume that air is getting into the suction side between tank and lift pump. Bleeding the system as far as the injector block a number of times has not solved the problem. We've not bled the injectors themselves so far.
One other thing I've noticed, is that after a short period of running, on removing the engine filter bleed screw, the filter seems empty of fuel at the top, even though when bled a short time ealier it was full. I expected the fuel to be at the bleed hole level all the times in a fully airtight system but I wonder if that is correct and I'm misunderstanding the set-up? The filter outlet pipe at the injection block has a direct connection to the fuel return line it seems (I can see the fuel level in the filter move up and down as I waggle this line). So does air at the top of the filter come through the return line as part of normal functioning and is nothing to do suction leaks?
It's all bit puzzling...
Thoughts and ideas are welcome!
