pcatterall
I have one of those mystery leaks and would like to know if there is some diagnosis that will help me locate it.
Engine starts and runs well at normal cruising speeds BUT repeatedly has failed after prolonged use on tickover ( like waiting in a French lock). Once failed it needs a complete bleed to get going again.
The system ( on a 4108) has A water seperator, A filter with a water bowl then after the pump the main engine filter. All CAV units.
I have gone through the entire system , thought it was ok then it failed again.
Any clues as to the sort of leak that causes this sort of failure which may help me focus my attention will be valued.
Yes I know that CAV is old hat and guess I dont need the seperate seperator etc but this is the system I have!!
many thanks
many thanks
