pjrennie
I sail a forty year old 27ft Bicker Biga which I have owned for a couple of years, and I am still getting to know her.
Inspecting the boat I found a split in a (now brittle) Plastic Barbed Mushroom-Head Through-Hull Hose Connector located below the waterline; On clearing the cockpit locker I found it connected via a transparent hose to a galvanised steel bucket located in a cockpit locker containing our small gas cylinder for the gas hob.
I am unsure whether this was intended to drain any water entering the bucket (unlikely given the buckets location) or to allow any leaking gas to escape safely, (where the exit below the waterline is unlikely to provide assurance of discharge when moored).
I need to decide whether to i) simply replace ii) Fit a replacement above the waterline and block the resulting below water hole.
Advice appreciated on gas safety, and how best to seal the resulting hole, if required.
Thank You
Thank You
