NealB
The little manual priming lever on the fuel lift pump doesn't seem to do anything.
I realise there's a number of possible reasons why (and, yes, I've tried the easiest one of turning the engine over to change the cam position).
I've got a rubber bulb type primer lying around, and was thinking of fitting that.
Where should it go, please?
Options:
1 between tank and separator (this is gravity fed anyway, so I guess no point putting it there)?
2 between the separator and the lift pump (would it be able to push the fuel through the lift pump, and on to the filter?)
3 between lift pump and fuel filter?
4 between fuel filter and injection pump?
Thanks for any words of wisdom.
Options:
