Spirit (of Glenans)
I have absolutely no recollection of writing this replyYour first assessment of the buoys seems to be correct according to the info on the website linked below:
Rovinj - a Cruising Guide on the World Cruising and Sailing Wiki
What I would do would be to have a line prepared on the bow cleat and brought outside everything to the stern. I would then reverse up to the buoy, with a crew on the sugarscoop ready to take the line through the ring on the buoy. This would then be tied to it in a bowline loop large enough to reach the deck. A crew on the bow would then take up the slack and keep tension on the line as the boat is reversed towards the quay. The bowline would be perfectly secure as it will be under load when in use and would obviate the need for a doubled line. Upon departure the reverse of this procedure would keep the bow under control until clear of neighbouring boats, wherupon the bowline can be quickly released. If there is a strong crosswind and the bow line of the downwind boat is worryingly close to the stern, it might be worth surging the line out and motoring past the buoy before turning back to release it.
In Croatia there usually worthies on the quay who will take your stern lines (plural) , pass them through rings and return them to you, (for a tip!)
Tension your lines, fore and aft, so that you are held sufficiently clear of the quay to avoid damage to the rudder from underwater debris, fallen masonry, etc., and deploy your large ball fender and passarelle.
