stav
Hi, I try to run a little open boat for a spot of fishing but because of Jandavina it has to be run on zero budget. Therefore a couple of years ago I pulled an old outboard from the local skip the throttle and other parst where seized so I freed them all up and have use it for a couple of seasons with limited cooling water!
However at the end of last season I found it full of sea water: completely. So I removed what I could and filled with old diesel until this weekend when I have stripped t down completely A lot of fun and real therapy for how busy I am at work at the moment. So it is completely in bits down to crank, pistons and various aluminium castings.
So questions:
Does anybody think it will run again if reassembled? Bores smooth with no pitting/ridges etc and seem to be the original diameter 2.18"?
Where can I ge cheap spare parts: Currently need, complete gasket set, piston rings, and a thermostat. If it all goes together and starts will rebuild the water pump end.
It is a 1979 model 109B63B 9.hp twin cylinder evinrude.
I have found on the tinternet mallory and serra piston ring replacements but only in USA, are they available in UK?
Thoughts and ideas welcome.
Cheers.
So questions:
Cheers.
