lw395
I did wonder if 'adding a diode pack' really meant adding another rectifier pack to the three-phase of the alternator. Which is actually a valid route, but I've never seen it on a boat.
No idea why you'd want to raise such a shameful incident on here, as part of a battery thread![]()
As mentioned before by other forum members, you seem to have elected yourself as the font of all electrical knowledge on this forum. Now I’m not no moderator but your behaviour is that of a self-righteous, obnoxious, know it all. Referring to other people’s comnents on a discussion forum as “nonsense” is not required or well thought of. I’ll happily admit my faults and learn from on them. Such as when I hit the dock wall causing 2 grazes on the port side and then gunning it out of the lock gates at WOT, having been told by you that there was no speed restriction. You then took the helm downstairs and continued from there and ignored the radio call from lime house telling us to slow down. Remember, it’s all on CCTV.
No handbag match here but everybody makes mistakes, errors of judgement or just bad decisions. Boat ownership should not be of of any superiorness and I’ll again, happily admit that I’ve started my boat owning career and I’ll make mistakes and learn from them eventually working towards a commercially endorsed RYA certificate.
Paul
Suggest you and Mathew delete all the posts about your adventures on the Thames, go to the pub and buy eachother a pint.
You will both feel better for it and you won't look like plonkers on here!
No idea why he decided to include the post about the London trip, can't see how that's relevant to the thread, or even the forum. But as it was posted, i had to respond and correct the errors. Don't think the pub is on the cards somehow;
Hi,
It meant adding the users choice of diode pack, available in various guises by different manufacturers, using different technologies depending on cost and end user requirements. Whether a diode box, as used on huge numbers of boats, and still sold and fitted, even today or the newer lossless devices which are becoming more popular for replacements in systems where the old diode packs are failing or just generally being upgraded.
I’m sure you’ll agree, you’d ordinerially remove and decommission B+ connection from the alternator and strap B+ to the Diode pack or other variant of this device to give a split output from the device to give isolated charging outputs... simple really but unnecessary for a non technical end user to worry about.....
I don’t bore people with science generally as it confuses non technically minded customers who just want something that works.
Paul
Personally I wandered into this thread looking for some advice on *my* battery setup, but have greatly enjoyed the diversion into 'ming-mong ping-pong' and have settled down with a big bucket of popcorn to watch the entertainment. So don't you go spoiling the fun....Perhaps still better to get it out of the public domain, whatever the rights and wrongs.
My knowledge of electrics is basic bout I do know that there is a type of diode splitter with low loss so they are by no means redundant and are in some ways superior to VSRs. Also I don't think that increasing battery capacity is much use without the means to charge them. I'm not a fan of running the engine just to charge battery but it is simple.
<snip> rainbow Paul who I've found gives good advice about electrics (I ASSUME he's a professional).
