cloud7
we have been looking at the following , jeanneau 39 i , 39ds , beneteau 40 & 37 , and would really appreciate any opinions or if any members have spotted a nice clean one for sale, thks
Are there any differnce in the construction? Beneteau use an inner moulding like a egg crate glued to the hull for strength. Jeanneau used to mould GRP ribs and stringers against the hull for strength but not sure if they still do or have gone over to the cheaper egg crate system.
To me moulded ribs and stringers are better as damage after any incident is visible. With the egg crate its difficult to see if its become debonded and cracked away from the outer hull. unfortunately incidents do happend like going aground and hitting the odd thing!
I am of the same opinion.I've seen Beneteaux with wobbly bottoms because of impact damage.The hulls are stiff until the bond breaks.If and when that happens the problem is very difficult to correct because it's very hard to know where the damage has ocurred,Another thing that happens is water sloshing about between hull and moulding that can't be (or is very difficult to)pump dry.
Jeanneaus on the other hand use traditonal techniques where bulkheads , furniture and keel floors are bonded to the hull and deck(not the floors) .I know which one I'd go for.
Here's a radical thought, perhaps an inner tray moulding is a better idea! Like welding ships together rather than using rivets, a good idea eventually catches on.Thats why we bought a Jeanneau but I think (don't know) that many manufacturers and possibly jeanneau now use an inner moulding glued against the hull to achieve the strength. I think its a cheaper construction method and the drive for the lowest cost/value are driving manufacturers to this method.
It would be simpler to identify which ones don't. Bavaria has certainly for the past 10 years at least and unlike Benni's the tray is attached to the hull using grp laminate tabbing strips.Can anyone comment on whether Elan, Dufour, Hanse, Bavaria or Jeanneau now use this inner moulding method on their latest boats.
All boats are design for a certain owner, with a particular fatness of wallet and usage profile in mind. You will get far better feedback on this forum if you spend an extra 5 minutes writing a paragraph or two detailing how you intend to use your future yacht.we have been looking at the following , jeanneau 39 i , 39ds , beneteau 40 & 37 , and would really appreciate any opinions or if any members have spotted a nice clean one for sale, thks
fair point on type of sailing a so here goes:
Cruising range , portugal / med and crossings to lanzarote to winter
handling , wife and i short trips , crew of 3 long passages.
max lenght 11.99m to get berth availability beam max 3.99m
budget £100k pounds
condition must be modern to get wife approval
advice warmly received
budget £100k pounds
Cost effective AND structurally effective.IMHO inner mouldings are a cost effective way of strengthening a hull
