stuhaynes
I'm not going to make any apologies, but I've asked for advice on another forum I respect as well. This has been bugging me for years and now it's time to do something about it if I can.
The engine on our boat is original, a Coventry 'Godiva' 4 cylinder diesel, that's 60 years old. The cooling system was a sealed system when the boat was built, but sometime more than 25 years ago the original system was removed and replaced with a raw water type. The raw water does not pass through the engine but instead is injected directly into an exhaust manifold sleeve.
With this system the engine temperature never reaches more than 100 degrees fahrenheit. This has got to affect both performance and fuel consumption, not that you'd think so if you were to sail her. She seems capable of driving uphill and doesn't like diesel at all!
I want to increase the engine temperature to a compromise 70-80 degrees centigrade. This will help the engine and enable the oil to do its job properly.
My question is this. Does anyone know of a simple system that is capable of adjusting the cooling water, reliably, to affect the engine temperature? Restricting the water flow at the seacock is not an option because of the dangers of blockage.
Any thoughts?
Any thoughts?
