Advice about replacing jib halyard
Crinan12
6 Mar 2019
Hi folks at the end of last season I could not get our jib down from the mast. It was stuck. Someone kindly helped me with it (they had to go up the mast on a harness). I'm not sure what the problem was. Someone at the boatyard did explain but I didn't really understand the terminology.
Anyway the wire part or the halyard was all twisted (it was a mixture of rope/wire) and I need to replace it. Based on some internet research I intend to buy 30m of 8mm cruising dyneema. Does that sound the right sort of rope? It's a 30ft seamaster 925.
Also there seems to be lots of options for how the ends of the halyards are finished. I guess the end that is down at the mast is just heat sealed? Does the end that attaches to the halyard need a particular finish - whipped, spliced,eye etc etc. I really have no idea. Everything boat related is totally new to me.
Finally to get the new halyard through the mast i understand that you have to attach it to the old halyard and pull it through the mast. I have bought a needle and some twine for that. Do i need anything else?
Any help would be appreciated and please feel free to state the very obvious!
Thanks v much
8mm Dynema has breaking strain > 2 ton. Someone with more knowledge than me can presumably tell if that is what you need. It seems quite a lot to me.
What is the current setup - how thick is the wire? How thick is the rope. The reason (as I understand it) for wire and rope is to reduce stretch. You've correctly figured that Dynema can do the same. The rope thickness and wire thickness currently are what matter - the new rope needs to fit the blocks etc.
What is on the end of the wire currently? I'd expect an eye with a shackle. You can do the same in Dynema. You may want a thimble. BUT - you might not need an eye. Take a look at this: https://www.animatedknots.com/halyard/index.php - advantage - if the rope wears at the end - cut off a few inches and all your wear points move and no need to be a splicing ace. I'd use a snap shackle personally. Big not stops the halyard being pulled into the mast if it all goes wrong. Dinghy guys use this: http://www.wayfarer-international.org/WIT/race.related/RiggingTips/TonJaspers/TJhalsheet.html Not sure why it couldn't apply to big boats
the end coming out the mast. Yes heat seal it, but you want some form of stopper somewhere that stops it going up the mast! Have enough spare to shorten things later but not too much to trip over if you can.
Is your mast ~ 40ft - in which case you need 40ft up, 40ft back down and enough rope back to the blocks. 90ft perhaps? So your 30m is about right. But Dynema is not cheap. You'll probably be left with a few feet of scrap...
Stitch and tape the rope. Pull GENTLY. Don't try to pull a splice through - the blocks will not be big enough. Wear gloves.
Hi thanks for all that
I don't know the thickness of the wire or the existing rope or if it is on a shackle because the mast is under a cover at the boatyard and I can't access it until they uncover it
I was hoping to order the halyard on line and then fit it when I next go to the boatyard (it's a 2 hour drive ). But it sounds like I might be best to have a look at the set up before buying anything. Someone said to me you can go to as thin a diameter of halyard as you want but just possibly not thicker because it might not fit the sheave- does that sound right ?
I'm not sure of mast height but I found a diagram on line that says length of foretriangle is 38ft so I was basing the 30 metres on that and adding in a bit extra
Thanks for all the other tips that's very useful
If your original halyard was wire/rope combo the sheave at the masthead may have a narrow almost V-shaped groove designed for wire instead of a U-shaped one for rope. This MAY damage the rope, but equally well you may well get away with it unchanged for years.
I've just replaced a 10mm braided polyester halyard with 10mm Spectra/dyneema: I used the halyard hitch at the top, but whipped the end where it's knotted before making the knot, then left about an inch and a half of the end out from the knot and whipped that tightly to the standing part. Dyneema can make knots "creep" undone. Halyard hitches are excellent for polyester ropes.
On a sea master 925 the mast will be approx 10m. Are you sure it's a wire/rope halyard. That means the wire is spliced to the rope. It's done to avoid stretch but rare on a cruising boat.
From what you say and if you have roller reeling I think you might have had a halyard wrap. This may have caused the wire forestay to start untwisting in which case you need a new forestay not a halyard.
Assuming the forestay is good then just replace the halyard with 10mm braid. Much cheaper than dyneema which isn't necessary. Just wrap and sew some twine around the ends to stop fraying. Even some electrical tape works well if you put it on tight then cut through it to form an end. Look for "halyard knot" and attach to a shackle or straight on to your top swivel. As said you need enough to go from just above deck at the bow, up the mast, back down and back to your forestay halyard cleat or winch. 30m sounds about right.
The yard should allow you access to your mast, how are you supposed to do any work on it if they don't?
Hi Yes it is definitely rope and wire
I don't think there is a problem with the forestay. Both the the chap that went up the mast and the boat yard manager said it was the way it had been rigged. The yard manager mentioned something about a block. It was all a foreign language to me. I did call him to ask what the problem was but he can't remember.
At Crinan they put a big cover over the masts for the winter and you can't get in to look at them. They are taking it off soon though so I'll go and try and find out what the problem is. I could just ask the boatyard to sort it but I am guessing that will be expensive so i would rather give it a bash myself.
In that case I'd just replace it with 10mm braid. Cut of the wire eye loop or what ever is attached at the sail end. lay the wire alongside the new halyard overlapping about 10 inches with a few turns of the wire around the new halyard over the 10 inches. PVC electrical tape tightly over the lot and pull the new halyard through from the exit at the bottom of the mast. It's very easy if the mast is off the boat as you can feed the join in the new and old halyard around the mast head sheave as you pull through the new one.
Personally, and just to give you another slant, I would buy a length of mouseline about twice the height of the mast plus two or three metres. You want something thinner, maybe 3 or 4mm. Polyester braid is fine (but can wear if you leave it in all winter with the mast up). I would sew a loop with strong sailmakers thread onto the end of the rope part of the halyard, attach the loop to the mouseline, and pull the wire out while pulling mouseline in. Now you have the halyard free and can design and make a new halyard to suit. I agree that dyneema is probably better that you need - low stretch braided polyester would be fine, but beware going too cheap - cheaper rope can twist maddeningly.
Sew a loop onto the end of the new halyard and attach the mouseline in order to pull the new halyard in - you have to puzzle out which end to attach to which but it's easy enough.
Using a mouseline is not necessary, but it's a skill you'll be glad of - getting a taped join stuck in a sheave cover entrance or similar with the mast up is a never-again experience. I take our halyards out each winter to wash them and check them over, replacing them with mouselines.
I replaced the jib halyard last year.
Put a mousing line of the end of the old halyard and pulled it out. measured the old halyard and asked the very nice people at Jimmy Green to make me up one. I moved from 12 mm (can't think why a previous owner needed that diameter a line) to 10 mm. I don't race so dynema would be way over the top.
I use 8mm dyneema braid covered for my jib halyard in place of the original wire a braid. I must say even on a 21 fter the stretch of the halyard is disappointing. It needs to be nipped up after a bit of use. Not a problem with furling jib but i use hank on and drop the jib for spin runs so end up pulling up the jib several times in a short race.
As said if the ends of the 2 halyards (old and new) are heat sealed you sew through the rope about 1cm in from the end looping around to pull the 2 ends face to face. Do about 8 stitches this way all around the circumference. A little tape over the join and pull it through. ol'will
As other have said, a cruising dyneema type rope attached to the halyard shackle with a special knot (the Jeanneau owners site had a good pictorial guide) is the ideal long term solution.
BUT note jwilson’s advice. It sounds quite probably that the upper halyard sheave is at least stuck/sticky and quite probably sharp edged due to the wire. This definitely needs a good check over. Unless spinning freely and absolutely no sharp edges you might just get the opposite problem - the sail falling down as the rope cuts through (or perhaps more likely a new rope with damage in the middle)
Thanks guys all very useful
I'd be bloody lost without this forum I must admit.
Dyneema isn't actually that much more expensive really. Say £2.50 instead of £2 a metre
I often wonder about quotes like this...
Why would a cruising sailor not want to get the best from their boat? A few degrees higher, a couple of tenths faster, a degree or two less heel - they're all incremental gains which may result in clearing a headland, beating a foul tide, sailing out of trouble or just getting to the pub before it closes.
I don't really know anything about sailing so I don't know
But if sailing is anything like other hobbies you seem to get some folk who really care about shaving weight and squeezing every bit of performance and others that don't
I'm in the latter category but each to their own I suppose !
I don't even know how long dyneema has been about, but presumably people managed okay without if before hand!
Cheers
I would suggest you use a mousing line as close to the actual line being swapped out. I have had narrower mousing line jam or jump the masthead pulley. A pest if the mast is at ground level, but a real pain if you have to go up to sort things out.
I would always arrange a butt connection- but sew the ends together several times. Then tape over the joint (not too much!) Even apply some sailkote teflon to the outside of the joint. If you have avoided the mouse coming off the the pully, then hauling the new rope back will be easy. I just replaced 43m of main halyard with the mast in place and no issues.
Thanks pagoda
I'm going to Crinan tomorrow to try this
I'm not quite sure what you mean thou - Not your fault it's just I struggle with the terminology and visualising things
When you say a mousing line ' as close to the actual line being swapped out' do you mean close in terms of diameter ?
Also do you recommend a butt join because it is less likely to catch ?someone else suggested laying them side by side and taping together
Finally my mast is down - does your advice still apply?
Thanks v much
Laying two lengths of the same diameter together and taping will never work. It might with a thin mousing line but why bother with a mousing line when you are replacing the halyard. I'd go with Pagoda's method. Cut the ends at 90 degrees, butt to butt, whip the ends and sew together. Pull the new one in with the old one.
If you use dynema you can go down a size in diameter which makes hoisting easier.But you need a decent dynema not cheepo rubbish
You eliminate most of the stretch & the sail will not keep getting a baggy luff & creases as gusts hit it & the halyard stretches
You do not have to over tighten the luff to avoid this so do less damage to a sail in the long term. So it is not just about performance
My dynema halyard has a dynema protector sleeve over the end 600mm because I found that I was getting wear in the point where it went through the mast aligner & halyard sheeve. This stopped that. I put it on myself as I know how to splice the end into the lay of the rope. I suggest that you might get a rigger to do it for you. The reason I suggest this is because if you have a sheave designed for a wire it would help protect the halyard.
I attach my halyard to the furler by passing the end through the shackle & putting an overhand knot in the halyard so it cannot pull back through.
Works Ok & the protector prevents any damage
