[70521]
+1Drain the carb bowl after every use and keep the fuel in the tank fresh and you will never ever get the problem again
When I finish with the engine if gets flushed with fresh water with the the fuel switch in the off position to empty the carb bowl.
The other trick is never let any water in the tank. Currently using fuel that has been in the green can for 18 months with no problem.
