cmedsailor
Has anyone added an additional fuel tank to a Beneteau Oceanis 361? Any ideas how to do this?
The only difficult thing is finding space, if its the same as the 351 and 381 then the original is under the aft cabin(s) bunks mid way. You could put another over the prop shaft (limiting access) or in one of the lockers. Question is why? both my tanks were/are good for a days motoring.Has anyone added an additional fuel tank to a Beneteau Oceanis 361? Any ideas how to do this?
OK the original is in the same place as mine, I always carry a blue "bidon" 5 gall plastic drum in the locker and top where necessary, I must say crossing the Irish sea in the 351 (VP2030) and running the donk for 16 hours only used 50 ltrs ish.The original is behind the gear box, above prop shaft (between the two cabins) and is only 75 litres. Using around 3lt/hr I could motor (if necessary of course) for only about 15-18 hours and then refuel (I wouldn't like to leave the tank with less than 20lt in it).
Lockers are huge, definately there is space for an extra tank. Question though is how I could connect it to the squeezed original and have a proper and tidy work.
Tranona yes there is plenty of space. On the starboard side there is a 170lt water tank, therefore I could have a similar fuel tank on the port side. Also there is space in the lockers. Space is not a problem. Biggest complexity is how to make a nice and tidy work with pipes, valves etc to connect the two tanks as well as be able to fill the additional tank with fuel easily.
