Burnham Bob
I've offered to help a friend winterise his 1GM10. However, when I used to winterise mine, I used to run the engine up to hot using a hose with a squeeze trigger to keep the Vetus water strainer filled up, and allowing the water from the exhaust to run out onto the concrete in the drive. (In those days I had a big enough house to store the boat in the front garden.) Once the engine was hot I knew the thermostat was open so when I poured in four litres of 50/50 antifreeze I knew it was going all the way round the block, out the exhaust and into the water trap.
Trouble is, my friend's boat is in the boatyard shed. No running water and hardly receptive to the idea of gallons of water on the floor. Did I really need to run the engine up to hot to open the thermostat? Thinking about it, the antisyphon valve would have released pressure while the thermostat was still open and the block would have drained - I think. So, there was no need to circulate antifreeze round the block as the waterways were empty. Adding antifreeze with the thermostat closed and just running the engine for enough time to suck through two coke bottles worth of 50/50 should protect the raw water system etc.
Admittedly a hot engine made the oil change easier too, but it's going to be difficult in the shed. What's the forum's view?
