alisdair4
My Rival has a fairly deep bilge, and two manual bilge pumps, one operated from on-deck, and one from the cabin sole. I want to add an automatic pump, as the boat is going to live on a mooring. I want to use the existing pump outlet(s) , so must tee in to the outlet above the manual pump. The question is: does the non-return valve go in the outlet pipe from the manual pump (about 40mm ID) or the electric pump (19mm ID) ie, if there is no NRV in the larger pipe, could water that is pumped up electically drain back in via the manual pump. Sorry this sounds complicated -I would attach a diagram but I don't know how to!
