Adding a NMEA 2000 device to my SeaTalk-NG network
mrming
28 Jul 2012
immaculateyachts on Instagram
instagram.com
My boat came with Raymarine electronics:
  • e Series plotter
  • EV-100 pilot with P70 control head
  • Wind, depth, log
The rotary controller on the plotter is failing, so am planning to upgrade it.
My Em-trak b924 AIS transponder is currently connected direct to the plotter via NMEA0183.
The Axiom+ plotter I want to upgrade to doesn't have a 0183 socket, so I'd like to bridge the AIS transponder into the SeaTalk-NG network.
Am assuming I can use one of the Raymarine adapter cables to connect the AIS from its NMEA 2000 connector. Is this correct?
The current STNG devices are all connected via a 5 way connector which is full. How do I add another socket so I can add the above as a spur cable?
Any pointers greatly appreciated. :)
KompetentKrew
27 May 2018
SeaTalkNG is NMEA 2000, just with different connectors.
NMEA 2000 has a "backbone" configuration like this:
You should always try to think of your network in these terms - your backbone might only be a short one right now, but conceptually it can go from bow to stern, with different devices T-ing off it wherever necessary.
The backbone has a terminator at each end, and in between is backbone cable and T-connectors.
The T-connectior is the "junction" by which actual devices are connected. (The cable between the device and the T is called a "drop cable".)
This is a SeaTalkNG style T-connector:
I think this is what you have:
This is really just 3 T-connectors in a single plastic case,​
With the Raymarine SeaTalkNG styling, the white connector is for the drop cable and the blue connector is for the backbone.
Probably the easiest thing to do is to buy another Raymarine "5-way" and then join the two with a SeaTalkNG backbone cable.
Then add the Em-trak transponder and the new plotter to the SeaTalkNG backbone using the appropriate NMEA 2000 to SeaTalkNG drop cables. I can't remember what gender you need, sorry, but it'll probably be apparent from inspection.
Useful search: Search Results for stng nmea |
PaulRainbow
16 May 2016
Suffolk
The advice in post #2 is all correct, but there is also another option.
Remove one of the blue terminators and in it's place fit a STNG to N2K backbone adaptor. Connect two N2K T connectors to the backbone adaptor cable and fit a N2K terminator to the second T. You can now use standard N2K cables for the Axiom and AIS and if you decide to fit any additional N2K devices in future you can just add another T connector.
Another option would be to fit a 4 way N2K port instead of separate T connectors.
Buck Turgidson
10 Apr 2012
Zürich
One thing to look out for is the orientation of t connectors if extending the network they are not all oriented the same way which can be annoying. I wanted to extend one of my multiple drop connectors but the T I bought was a different brand and 90° offset to the original so I couldn't just plug it in to the end as it was fixed on a bulkhead.
mrming
28 Jul 2012
instagram.com
Very helpful thanks all. I’m going to reccy it this weekend, and now I feel like I’m more informed. Sounds like I need to make a choice between adding a little N2K backbone or extending the SeaTalk-NG one. Will have a think! 🙂
DrSpock
31 Aug 2016
The failing rotary control can normally be fixed by dismantling and cleaning with electrical cleaner.
mrming
28 Jul 2012
instagram.com
Thanks for all the help so far! We've now done a bit of a reccy:
  • Plotter will be sited by the companionway (where the current one is)
  • AIS is at the nav table
  • I'm going to get a NMEA 2000 VHF (also at the nav table) and bring that in to the network as well
  • There's a compartment under the quarter berth where batteries, autopilot computer, charger, MPPT controller etc are sited
    • There's an easily accessible 5 way SeaTalk-NG connector here, the backbone continues astern after this connector.
    • If we take option 1 from @KompetentKrew above we can
      • Add in another 5 way connector to the backbone
      • For the VHF and AIS Run 2 x NMEA 2000 cables from the nav table, fit the SeaTalk-NG adapter cables and plug them in to the new 5 way
      • For the new Axiom+ plotter do the same, but from it's location by the companionway
    • If we wanted to take option 2 as suggested by @PaulRainbow
      • This would allow us to only have one cable running from the nav station (easier to route)
      • We could then easily add new N2K devices in the nav station area in the future
      • So this sounds great, BUT:
        • I have one question. The part of the SeaTalk-NG backbone that's convenient is not at the end - the backbone continues aft, presumably to reach the autopilot control head etc.
        • If I'm understanding correctly, the N2K backbone must be joined to the END of the SeaTalk-NG backbone.
        • Is that correct? Or is there a way to join in a N2K backbone part of the way along the SeaTalk-NG backbone?
Any more help from the experts would be greatly appreciated. Confident we can do option 1, but option 2 would be neater and more future proof. :)
PaulRainbow
16 May 2016
Suffolk
You can use option 2. Disconnect the STNG backbone cable from the 5 way connector, fit a STNG to N2K adaptor cable, fit 3 T connectors, then fit another STNG to N2K backbone adaptor cable to the STNG backbone cable going aft.
mrming
28 Jul 2012
instagram.com
That’s great thanks Paul!
The 3 T pieces in your suggestion would be “drops” for individual N2K devices, is that correct?
Ideally I want to run a single N2K backbone cable over to the nav station area where I can T multiple devices onto it. But am I right in thinking this would ultimately have to come back and re-join the STNG backbone? I might be able to figure out a route to do that if so…
KompetentKrew
27 May 2018
It's all one backbone. SeaTalkNG is literally just NMEA 2000 with different connectors on.*
So you have a terminator at the chart table, a couple of T's at the chart table, and then the backbone runs back and joins your current deices wherever they are.
If you add an NMEA 2000 speed or wind transducer then you just remove the terminator at the chart table and run the backbone forward from there.
* unless you also connect SeaTalk1 devices, but hopefully that doesn't apply
mrming
28 Jul 2012
instagram.com
Yes the penny has dropped on it all being one backbone - finally. 😀
My issue is I’m adding into the middle rather than onto an end, but if my new understanding is correct, that will be fine. Obv you chaps can’t see the layout in the boat, but I think it will require the N2K part to go to the nav station area and come back, at which point it’s joined to the aft section of the STNG backbone.
PaulRainbow
16 May 2016
Suffolk
That's correct.
mrming
28 Jul 2012
instagram.com
Hey all, I’ve started putting the N2K section of the backbone in, but have run into a bit of a logic problem.
As described above, we’re “breaking” the STNG backbone to insert a N2K section into it. To make the break I take out the male (blue) STNG plug that’s in my 5 way STNG socket in the battery compartment.
To create the N2K section I plug in a STNG female (blue) to N2K adapter and then run the N2K backbone cable off to my nav station. This goes into a Actisense T piece giving me 4 N2K drops at the chart table. The N2K backbone then runs back to the battery compartment area.
So far so good, but now the problem. I have a loose STNG blue FEMALE plug which I need to join onto. For this I need a N2K to STNG blue MALE adapter or adapter cable. I’ve scoured the web for one of these and it doesn’t seem to exist.
Am I missing something obvious? Any ideas greatly appreciated @PaulRainbow @KompetentKrew 🙂.
Edit - I think I may have found the answer - one of these: SeaTalk NG Extender A06030.
PaulRainbow
16 May 2016
Suffolk
Yes, that will do it, or you can adapt the existing STNG cable by cutting the end off of it and splicing a N2K cable to it. If the N2K cable is compliant, the colours should match the STNG cable, so just join them like for like.
mrming
28 Jul 2012
instagram.com
Just a quick note to say this work is now done and everything is working nicely.
To summarise, I created a new section in my existing STNG backbone using N2K cables, enabling me to bring my existing Em-Trak b924 AIS, and a new B&G VHF into the predominantly STNG network.
To make the initial connections I used Raymarine’s STNG backbone (blue plugs) to N2K adapter cables, and one of them was used in conjunction with a Raymarine Seatalk NG Extender. From there it was standard N2K cables.
When creating the N2K drops, to save space and leave more connections for the future, I used an Actisense 4 Way Micro T-Piece rather than the standard T connections.
I also upgraded my Raymarine e7 to an Axiom+ 9, which was just a matter of using the supplied adapter cable to plug into the STNG backbone, in the socket vacated by the e7.
Big thanks to @PaulRainbow and @KompetentKrew for the help. 🙂
PaulRainbow
16 May 2016
Suffolk
Great to hear it's all working for you, thanks for posting the results.
