oncewaswafu
AD41P Rev limiting
Hi all. Had a problem occur twice now, as follows.
Transitting Pompey harbour at hull speed, temperature climbs to 80 degC which is its normal OT.
Then, a while later, Temp gauge flickered and dropped to zero. Then, trial and error showed the engine would not accelerate above 2000rpm.
On the first accasion the temp gauge came back to life, and normal engine response was available. Yesterday, not so.
Hull sparkling, props ditto, new fuel filters, oil and filter. New impeller. Plenty of water out of the drive. Coolant level good.
I'm thinking there must be an interlock between the temp and the governor, as in the Overtemp scenario.
Would anyone like to comment? Or at least inform me where the temp sensor/sender is?
Thanks in advance
Thanks in advance
