Geoff L
Just in the process of rebuilding an AB41B 1990 engine (installed in a Targa 33) and have hit a problem with the thrust bearing. The crank had to be ground resulting in +0.5 mm main bearings diametre (incl thrust). Thrust bearing supplied 876521 has thicker thrust bearing sides than the original 876523. The full volvo engine repair kit contains 2 thrust bearings, 876523 and 876519, both standard crank diametre and therefore no use) which I assume is to suit the specs of 2 engine versions. I have been back to the supplier but they are only able to provide the +0.5mm thrust bearings with the thicker thrust bearing sides. Sending the crank back for further machining would not be a problem but to fit the bearing 976521 the block and end cap would also have to be machined as the inner width of the new thrust bearing is 30.4mm and the block and end cap are 31mm wide.
Anybody come across this before?
