ACR and Solar to battery side of master switch.
Yellow Ballad
10 Oct 2013
Sundance, Bristol Channel
I'm getting closer to getting the rewire sorted but I have another I think I know the answer to it question.
Master switch (Bluesea M series) with a Engine and Leisure + cable to each terminal, terminal 1-2 (plus forwarding terminals 3-4 ), probably 1.5m away from the battery.
I wanted to locate my ACR above master switch but is it ok to link the ACR on the master switch terminals 1-2 rather then another cable run to the battery terminals? It would mean 6" of cable rather then 1.5m each.
Also I assume it's ok to link my solar positive to the leisure terminal 2 rather then another cable run to the battery terminal.
Battery terminals are fused before you suggest it ;)
Cheers
Cheers
Yes but if the battery terminals have "mega fuses" you may need to fit more a appropriately rated fuse in the connection for the solar system, which is presumably not plumbed in with battery cable.
I'd concur with all of that :encouragement:
