Eviltail
Hello
I have read two contrasting methods of determining the state of charge of a battery. The first requires you to leave the battery for a period of at least 24hrs following charging, without any discharge, and then measure directly accross the terminals with all loads switched off. The second states that the measurement should be made following charging, however it is first necessary to apply a high load to rid the battery of what was called "ghost charge", then the measurement is made as before.
Can anyone advise me as to which method gives the most accurate result? Or are they both synonymous?
Cheers,
John
Cheers,
John
