franksingleton
As a meteorologist I am all too aware that there is always some uncertainty in forecasts, See http://weather.mailasail.com/Franks-Weather/Forecast-Accuracy-Limitations. That is why the Met Office and the other major payers run ensembles of forecasts. Whilst I expect commercial firms to make exaggerated claims about their products, I never fail to be amazed at claims about forecasts such as
…………detailed marine forecast
Outstanding accuracy
Worldwide forecasts using a 1km resolution
……….showing detail every hour!
Superior forecasting …………
Detailed ……. information for your local area
……highest quality weather forecast data
precise …..… accuracy of one nautical mile
No names no pack drill. Of course, much depends on what is meant by words such as “accuracy” and “precise.” However, I have now seen a statement that says
“.............., our data is exceptionally accurate. We produce forecast data with market-leading Mean Absolute Error (MAE) figures: within 1m/s on a 36 hour forecast against observed data over a year.”
I have no reason to doubt the accuracy of the statement but, an error of 1 m/s ie about 2 knots sounds impressive for a 36 hour forecast. However, what does MAE mean? I can see how it works for a scalar quantity such as temperature although the usual measure of accuracy would be RMSE or SD (root mean square error or standard deviation.)
It is not at all clear how MAE works for a vector quantity, ie wind. If it refers just to the wind speed then a forecast of 240 ° 10 m/s and an outcome of 300° 10 m/s would be a zero error of wind speed but a vector error of 10 m/s. In other words, instead of a fast one reef reach from Sables d’Olonne to Ile d’Yeu, it would be a two reef hard slog.
Have I got it wrong? Is there some other interpretation of MAE as applied to wind forecasts? The usual statistic is RMSVE – root mean square vector error.
I note that the Met Office quotes accuracy figures for temperatures, rainfall, sunshine, weather but not for surface wind. I assume that this might be because of the high variability of wind in space and time.
Any views on MAE and wind?
