whisper
Following the major problems with our DP-E trim, reported on earlier, we bought a new pump and had it fitted. This follows repairs to the trim pistons which was intended to resolve the situation.
B****r me if on the 2nd test run we had the same problem reappear.
Symptoms are :-
1) When stationary, trim works as it should.
2) Under low load in forward gear the trim raises up when required but drops back down rapidly on its own. eg will if required raise up to +5. Then over about 10 secs drop back to -3
If one then knocks it out of gear the trim rises off its own bat from -3 to +4. It's as if it is acting like a spring.
3) When more power is applied in forward gear the trim won't lift up at all.
4) When put into reverse the trim rises continually, of its own accord. Then, when knocked out of reverse, it falls back down again.
This problem has only appeared since the existing rams were repaired.
Any more suggestions re. a cure would be greatfully accepted before we have to fork out yet another large sum for a new pair of rams.
Anyone know where the cheapest rams could scourced - I'd normally go via Keypart?
Symptoms are :-
