Birdseye
I only thought of modding the rudder if I had to cut back at bit at the forward top end to allow for a skeg - a fin really since it wont be attached to the rudder itself. As it happens the hull area in front of the rudder is flat and about 10cm wide so ideal for through bolting a plate to hold the skeg.They look pretty vertical to me compared to many.
Lead lower ballast is great and unusual these days providing a great ballast ratio.
Quite full forward sections as well, providing good buoyancy upwind compared to the fine entry/wide sterns that tend to dive when on the wind.
I think I'd be tempted to add a skeg.
Probably 50% of the depth of the rudder and 25% of the width.
If you glass in a 10 or 12 mm 316 plate with welded studs to the stub area in front of the rudder you could bolt on and try one without having to break through the hull. ( I hate holes in boats)
Changes to the rudder, in my view will have little effect other than the obvious, bigger area>more leverage>more turning moment, Smaller area>less leverage>less turning moment.
One other thought is, where are your rudder stops set?
If for example they are set at 35degrees you could try dropping it by 5 or 10 degrees.
The rudder stops will be about 35 deg either side - not easy to change because ( from meory) they are formed by an arc cut out of the thick stainless plate that holds the rudder shaft.
Having said all this, I am not sure that the issue is the boat so much as a geriatric me trying to race it single handed with half mile legs between marks. I will know much better when I start racing with crew outside the barrage beginning september. Certainly I am managing far better now than when I started.
