A revolutionary new development which will change the maritime industry forever
Do you take bookings for lectures? I am sure my engineering institution could fit you in this winters programme and we have a few members who work in the marine industry.
Am busy sorting the finer details of the system. Might be free in the summer if that is convenient?
Still a problem getting the boat out of the tank with its wet antifoul. Remember this is a 10 minute operation. I'll plan and install a Dyson hand drying system for you for just 20% of your profits.
A quick calc and you're going to need one hell of a lorry.
A container 15metres long x 4metres wide x 2m deep = 120m3 so approx 120tons if its the same density as water.... And that's just for a 45 footer :D
Initially the service will only be available for boats of up to 25 foot due to the problems you have mentioned. We have a slightly different delivery system in mind for the larger vessels.
But you haven't allowed for the fact the container would be V-SHAPED ... ...
I hope you get a good discount on the antifoul, as that lot works out at approx £3,360,000 @£28 per litre...:D most of which you will never use.
I'm not sure about the lift and dip method of application. Wouldn't it be easier to lift and shoot with a paint gun? OK something a bit bigger might be needed. Army surplus places sometimes sell off old tanks. A Chieftain should do it. This would have the added bonus of being able to deliver special paint effects. Might have to carry out some pressure testing first though. Does your liability insurance cover sinking?
shirley the best way to design the tank on the lorry is to have the shape controlled by a computer, so that - for each class of boat - external rams ensure that the tank assumes a female mould shape only millimetres larger than the standard hull ?
This way, a quick recalculation shows that you will need only a few litres of antifoul in the "ShipBath" (Pat Pending, Trademark Applied for).
Indeed, why stop at antifouling ? With the tank perforated by thousand of small holes attached to powerful hydraulic pumps, you will be able to pressure-blast the hull clean, and with an abrasive medium such as boron granules remove all previous anti-fouling, prior to connecting the jets to the drums containing antifouling and filling the mould with the anti-foul of choice.
Colour of course is not difficulty with a multi-jet system, as the jets can be linked under CNC to drums of different AF colour. Stripes, blobs, even graduated transitional colours will be achieved. Sponsors' logos, rude messages to submarines, optical patterns to convince marina operators that the vessel is in fact several metres shorter than the nominal length - all is possible.
