Madhatter
What difference does it make if you put your boat on a trailer stern first (besides the aerodynamics of the" blunt end " )?
Derrick
Derrick
The Westerly 25 is designed to be towed "backwards".
The keel configuration keeps the weight forward of the axle & the nose weight was perfect if the boat was in the right place (because of adjustment allowances, it could be too far forward or too far back). There is no over hang at the front but the bow is high in the air & the rear overhang is well above most vehicles allowing good manouverability in tight spaces.
The trailer is quite short too for strorage when not in use.
It's easier to hang the lights & number plate on the transom than on the bow.
The number plate & lights are a permanent fitment to the trailer axle. But one needs to be aware of the legal situation for overhangs.
I don't see how the trailer will be shorter if the boat is mounted stern-first.
My Foxcub was bow-first. Assume the GoG is ahead of the axle and you will see that reversing the boat will require a longer drawbar as there is more boat behind the CoG than in front.
(snip)
[snip]
