rotrax
The Webasto heating pipes on our boat were, IMHO, poorly routed by the supplying dealer. It is a blown air system with five outlets. A 90mm pipe goes from the heater unit into the engine space where it reduces to 75mm and feeds a two way 60mm diverter. This feeds the heads, owners cabin and guest cabin. The two 75mm pipes feed the pilothouse and galley.
It all worked well, but in the eight years of ownership the installation problem got worse every time I worked on the engine, especially changing the oil filter.
Four joints had to be disconnected to give access. Those of you that have such systems will know that the aluminium foil/cardboard ducting is not very durable. Not after eight years, anyway.
I decided to move the major junction towards the rear of the large engine compartment and install two new longer 60mm pipes. Only one 60mm join will have to be moved in future when changing the oil filter. I ordered what I needed, but baulked at paying £7.00 each for 75mm male connectors. I needed three.
I used bean tins instead. I removed both ends and found them perfect.
I am sure I plagarised the idea from the tunneler's of the great escape who used tin cans for their ventilation system....................................
