VandKoala
Active Member
So I have been sanding the bottom paint and noticed a crack in the gel coat, dead-center of the bottom of the hull, in front of the keel. Inspecting a bit closer I saw it repeating further and further. Sanding the gelcoat away showed there is a long, about 0.5cm deep "cut" that goes from the keel to the very bow of the boat, including where it starts to go up on the nose of the boat. It has been filled with something, that has cracked in some places and thus cracked gel coat.
Removing some old through-hulls indicates that the hull thickness is at least about 1.5-2cm, probably more at the bottom. Have you ever seen something similar? Should I be worried about the structural strength of the boat?
My current thought is to clean it all up and remove the filler. Fill the groove
with thickened and fiber-reinforced epoxy
, and add a couple of layers of fiberglass on top (while chemical bonding is still "on"). Then after fairing/sanding seal it with a two-component primer and bottom paint it.
