nigelmercier
RIP
- Joined
- 20 Jun 2007
- Messages
- 16,234
- Location
- Live in Kent, boat in Canary Islands
Maybe you can design me an equivalent with 4/5 transistors?
ROFL
I wish.........this is the back of a red/white constant current LED lamp....where am I going wrong....... Maybe you can design me an equivalent with 4/5 transistors?
We've been following this thread with interest ..........its all gone quiet about the test lamp which looked promising, ..........
I wait with 'baited' breathe for any 'enlightening' results?.................
can I ask ?, last year I eh acquired 5 strips of led's from a shop fridge lol,
and have been using them in my boat for the past year , should I be worried about them burning my boat to the water line, or just get on with it and ejoy the sunny weather up here in sunny loch lomond.
We've been following this thread with interest as we are undecided on the merits of buying cheap LED bulbs having heard mixed reports, mostly bad! and its all gone quiet about the test lamp which looked promising, I think. Any results yet Bluechip from the cheap lamp? Has anyone else on here done the same test yet?
I think you have to take a pragmatic view.
If you have the knowledge to understand the technical stuff you are doing that's fine. Its the knowledge gap that often bites you in the nether regions!
If electrical equipment is used in an environment its not designed for there are obvious risks. Items can and do overheat or the opposite can be true and devices can under perform. If its a garden light and it goes dim or overheats, so what. If its your anchor light that goes dim.....well the potential for trouble is fairly obvious.
I would suggest you satisfy yourself that your strips of LEDs are safe. Or you replace them with a product from a reputable supplier who offers you a reasonable warranty.
Regards
... as I said ... 2 transistors = constant current source. There's really no need for ICs, coils etc. for such a simple application...
As an aside if anyone uses spotlights with 20W halogen bulbs for reading I cannot recommend highly enough these LED spots bulbs - http://www.ebay.co.uk/itm/4-X-MR11-G...item27babc4cb9
Sorry for not getting back. I ran the lamp at the overvoltage settings I showed in the picture for 24 hours, it was still burning (not literally) brightly when SWMBO wanted her dining room table back and I had to stop the test.
There is no question in my mind that this lamp will not catch fire or melt or the diodes will not drop off the board regardless how long the test was run for.
I am now back on my boat and have bought the anchor light with me, I had planned to take some pics 'at anchor' and try and show the comparative brightness with other anchor lights, but the weather has been so horrible that we haven't left the marina.
Maybe tomorrow?
I have some 18 LED lamps on board that I use for interior lighting, none of them with the exception of some really powerful single LED, halogen spot light bulb replacements cost more than a couple of pounds each.
As I write this my boat battery is charging and the voltmeter is reading 13.33V. I fitted these LED's last winter and they must have run for 250 hours or more with no signs of any failure. These lamps were so cheap that I bought a few spares, so even if I did get a failure it wouldn't worry me, though if one caught fire that would be a different matter.
To satisfy myself that these interior lamps are safe I'll take one home and run it at the high overvoltage for an extended period and report back.
I am not expecting a problem.
As an aside if anyone uses spotlights with 20W halogen bulbs for reading I cannot recommend highly enough these LED spots bulbs - http://www.ebay.co.uk/itm/4-X-MR11-...6627129?pt=UK_Light_Bulbs&hash=item27babc4cb9, the light output is amazing and the current consumption just a miserly 1W
Maybe tomorrow?
I don't know what else to say!
Probably not worth bothering to say anything. Discussing electronic technicalities on a yacht forum is never going to be easy![]()
And its been informative.
We have learned ( and I certainly wasnt aware beforehand) that there are two types of led bulbs, resistor controlled and current controlled. We have learned that there can be a fire risk with some resistance controlled lights and how do you tell which are a risk and which arent before you buy? We also now know that resistance controlled bulbs use extra leccy at high voltages and thus negate part of the reason for buying leds ie leccy saving. And lastly we have learned that there are plausible reasons for the current controlled jobbies being a lot more expensive than the cheapo ebay resistance controlled jobbies.
I've been converted. For the sake of the small extra cost involved I will use current controlled leds to be sure I'm not going to set fire to my boat. And since he has brought the whole matter to light and responded politely and well to our usual forum harassment, I will buy mine from Adrian. I suggest the rest of you cheaseparers do so too! Cant say fairer than that
For the DIYer, is this a good way forward to limit current? ...
