A light at the end of the tunnel?
Yay!! When Howard pulls his finger out and stops holding it all back, we can all enjoy sensible levels and flows. C'mon Howard, I want to use the 2013 license I bought nearly four months ago!!
Before Howard arrives and bursts a blood vessel I am sure he would want you to know that he does NOT hold it all back - in fact if they did that the levels would be even higher ! All the weirs will be fully drawn (except possibly up in Moxons little corner of the world) and the lockies will be as pleased as you will when things get down closer to normal again. Will it happen by Easter ? Possibly but its still going to be perishing cold from the looks of things and not my idea of fun boating weather.
(Thinks ... I really should have stuck Bosun in kennels and gone to Oz with swmbo )
Oh yes, this is what it was like at Chertsey Bridge on 25th July 2007 - well, at least there was some blue sky and white clouds ! - I'll get me coat ..........
Dropped about 4'' in the past 24 hrs below Shepperton Weirs at Weybridge only another 2' to go to get normal levels. I have cleared the sludge off the decking for a third time I do hope it will be the last!
Look, look:
Lechlade to Oxford Back to Map ↓
Reach Current conditions
Upstream of St John's Lock CAUTION STREAM DECREASING
St John's Lock to Buscot Lock CAUTION STRONG STREAM
Buscot Lock to Grafton Lock CAUTION STRONG STREAM
Grafton Lock to Radcot Lock CAUTION STRONG STREAM
Radcot Lock to Rushey Lock CAUTION STRONG STREAM
Rushey Lock to Shifford Lock CAUTION STRONG STREAM
Shifford Lock to Northmoor Lock CAUTION STRONG STREAM
Northmoor Lock to Pinkhill Lock CAUTION STRONG STREAM
Pinkhill Lock to Eynsham Lock CAUTION STRONG STREAM
Eynsham Lock to King's Lock CAUTION STRONG STREAM
King's Lock to Godstow Lock CAUTION STREAM DECREASING
Godstow Lock to Osney Lock CAUTION STRONG STREAM
Osney Lock to Iffley Lock CAUTION STRONG STREAM
Oxford to Henley Back to Map ↓
Iffley Lock to Sandford Lock CAUTION STREAM DECREASING
Sandford Lock to Abingdon Lock CAUTION STRONG STREAM
Abingdon Lock to Culham Lock CAUTION STRONG STREAM
Culham Lock to Clifton Lock CAUTION STRONG STREAM
Clifton Lock to Day's Lock CAUTION STRONG STREAM
Day's Lock to Benson Lock CAUTION STRONG STREAM
Benson Lock to Cleeve Lock CAUTION STRONG STREAM
Cleeve Lock to Goring Lock CAUTION STRONG STREAM
Goring Lock to Whitchurch Lock CAUTION STRONG STREAM
Whitchurch Lock to Mapledurham Lock CAUTION STRONG STREAM
Mapledurham Lock to Caversham Lock CAUTION STRONG STREAM
Upstream of Blake's Lock NO STREAM WARNINGS
Caversham Lock to Sonning Lock CAUTION STRONG STREAM
Sonning Lock to Shiplake Lock CAUTION STRONG STREAM
Shiplake Lock to Marsh Lock CAUTION STRONG STREAM
Marsh Lock to Hambleden Lock CAUTION STRONG STREAM
Henley to Teddington Back to Map ↓
Hambleden Lock to Hurley Lock CAUTION STRONG STREAM
Hurley Lock to Temple Lock CAUTION STRONG STREAM
Temple Lock to Marlow Lock CAUTION STRONG STREAM
Marlow Lock to Cookham Lock CAUTION STRONG STREAM
Cookham Lock to Boulters Lock CAUTION STRONG STREAM
Boulters Lock to Bray Lock CAUTION STRONG STREAM
Bray Lock to Boveney Lock CAUTION STRONG STREAM
Boveney Lock to Romney Lock CAUTION STRONG STREAM
Romney Lock to Old Windsor Lock CAUTION STRONG STREAM
Old Windsor Lock to Bell Weir Lock CAUTION STRONG STREAM
Bell Weir Lock to Penton Hook Lock CAUTION STRONG STREAM
Penton Hook Lock to Chertsey Lock CAUTION STRONG STREAM
Chertsey Lock to Shepperton Lock CAUTION STRONG STREAM
Shepperton Lock to Sunbury Lock CAUTION STRONG STREAM
Sunbury Lock to Molesey Lock CAUTION STRONG STREAM
Molesey Lock to Teddington Lock CAUTION STRONG STREAM
Blakes? Shurley some mistake?
