A few pics of our trip to Limehouse...and an engine problem.
Nauti Fox
28 Oct 2003
Kent
www.facebook.com
Leaving Cuxton in the early morning, as we are on a drying berth and had to anchor at Stangate Creek for a couple of hours to await the incoming tide
The weather was cold and misty, the radar and AIS proving very handy tools.
By the time we got to the Barrier it was still a bit gloomy but the viz was a whole lot better.
We contacted Limehouse when we were passing Greenwich and were told to report outside, as soon as we arrived they swung the road bridge ( I hadn't known it was a road bridge) and had the lock ready. Its not the easiest entry but not bad with a little care, especially as you have to pass a restaurant (one of Gordan Ramseys) as you enter with lots of people watching.
The staff were very helpful and gave us a welcome pack with with a map of shops and restaurants and an electricity card, I found it all rather efficient and far better than the usual wait and scramble getting into St Kats.
The marina was secure although not as grand as St Kats but we enjoyed our stay. With a wider locking out window we were able to leave at 06.00 on Friday morning, I understand that if you are only staying overnight you can lock in and tie up to the public access moorings for free.
Here's a couple of pics from when we left.
Just after this I noticed the port engine temp was way up and the bloody alarm hadn't gone off! I shut the engine down and stopped and reversed the boat, restarted the engine and the temp didn't drop so decided to shut it down and carry on as Cheryl didn't want to steer in the dark while I was in amongst the engines. It would also be a bugger to pick up a mooring on one engine.
We'd reached the QE2 bridge before it had got light so I left Cheryl to steer with instructions to alter the revs on the engine if she needed any help and set to work to find the problem.
I started by closing the seacock, removing the strainer cover and opening it, good flow so no problem there, next stop remove the impellor backing plate and remove the impellor, all okay again, (but replaced it just in case it had been damaged) so I restarted the engine and loosened the raw water intercooler hose, it promptly sprayed me with freezing cold water, so yep, all alright there then.
The temp was still not right though so shut it down again.
Time to check the fresh water cooling so after leaving it for a while I gently cracked open a hose that joins near the thermostat, nothing, go and check the header tank (which is accessed by a filler cap outside on the deck) and sure enough it was very low, start to fill it with fresh water and it started to flow from the hose. Fill it to a reasonable level, start the engine and all is tickety boo, hurrah!
It must have got a blocked seawater inlet when we left Limehouse and as it got hot spat a lot of coolant out, which goes to the bilge. When I stopped the blockage must have been dislodged, but the fresh water cooling system then airlocked.
The rest of the trip was uneventful, thank goodness, but I'm annoyed at not seeing the temp rise earlier and of course need to fix the overtemp alarm which sounds a buzzer, although you can't check this on startup.
I'm glad I've got cast iron lumps as I'm not sure alloy would have come away unscathed.
Great pics Unit 18. I used Limehouse a lot in the past but have been here 5 years now.
__________________________________________________________
quote from your post surely this is not the Barley Mow I think it was called on the port side heading into the lock?
Thanks Nick, I'm sure they've been through worse in their 36 year history, I replaced the head gaskets on that one about five years ago, not a job I fancy doing often. /forums/images/graemlins/smile.gif
Nice pics and glad all turned out ok for you.....
Remember to check the strength of the antifreeze after your freshwater top up (prob done it) but worth a mention in the current cold spell.
Thanks, all taken care of.
What did surprise me was that the river up there was still pretty busy at that time, the clippers were flying about.
A few of the more wobbly pictures.
Thanks Piers, not a difficult one really, just a case of going in logical steps. The frustrating part was not being able to get started on it straight away but I didn't want to put pressure on Cheryl while wanting to try and sort it out before getting into open water.
Just heard from someone that came out of Limehouse this morning and apparently the whole basin had iced over! Lots of fresh water from the canal and river Lee I'd guess.
Thanks and the same to you and yours.
A couple of pictures that show good access to the engines.
To get to the basics its just a matter of lifting two panels from the middle of the saloon floor
The coolant hose
Enjoyed the pics, would love to cruise through cental London one day.
Note to oneself, learn a little more about marine diesel engines! /forums/images/graemlins/grin.gif
It used to be a fantastic stopover now it's an overpriced live on the hype type place just because it has Gordon Ramsey's name on it. Great location though.
Limehouse is still one of my favourite marinas, just walk 3 minutes downriver for some really old traditional waterside dockers pubs with proper grub.
Impressed you can do a "just in case" impeller change underway. I've thought about speedseal but it's so hard getting the rubber out there seems no point. I could change it at sea if I had to, but I really really wouldn't want to.
I think the important thing is having a container to put all the bits in (I use a sealed Tupperware box) so you don't lose anything down the bilge, if there's space I lay an old towel under there as well to hopefully catch anything I drop. Luckily (sort of) when we first got the boat I spent more time on one engine than two until we got things sorted which gives you a good grounding in on the move repairs. /forums/images/graemlins/smile.gif
Very kind of you to clear the crud out before we left! Sorry we didn't get a chance to catch up for a drink, the bloody mary's took a bit longer than usual to take effect, but we go the The Narrow, Ramsay's place for some very nice fish and chips, more bloody mary's and a few beers. Thankfully our lock out time was a bit more leisurely after a great brunch at a cafe/ shop in Mozaic square, eventually getting away about 1330, and arrived at Tedders about 1530. Saw someone on the pontoon near the Wharf, not sure if that was you Richard?
Picture of our marina this morning, not sure if this will come out though, a bit of a rookie with posting pgoto's...
http://i166.photobucket.com/albums/u92/targa34/marina.jpg [image]
[/image]
