Bouba
I also have always believed that.Sheesh. "Both engines" - the guy was talking about the same engine ffs - one engine not two - that is the whole point of the bit I quoted in red. It was the very same engine, run under the same conditions. If you have two of them and compare the 30%-er and the 70%-er the results would be identical. The 30% number arises only due to a different denominator, not any difference in numerator. That's the whole point. If the red part quoted above isn't explain that then it's a tougher thing to explain that I thought.
Rustybarge covers this in post 7. He says the denominator should be the continuous duty rating. For my Cats that is something like 900hp so if I'm pulling 630-720 hp from them that's 70-80% and they will last for ever. In the 1925hp version it would be nonsense to say the best way to run them for longest life is to take 70-80hp of 1925hp.
Therefore your golden rule of running at 80% is fundamentally flawed, unless your engine's max HP is its continuous duty rating, which obviously it isn't because yours are 700hp each from pretty small MAN motors with MAN's typical small/undersized journals. Your continuous duty rating is more like 300hp and if you want to take 80% of any number it should be 300hp. This is what the bit I quoted in red above is saying.
I don't doubt you could corroborate what you say on all sorts of forums and dockside bars, because other people misunderstand this too. Doesn't change a thing.
From your data it appears your cooling system isn't great. On my cats, whether I'm developing 150 or 1500 hp or anything in between, and in 10deg C seawater to 30deg, they ALWAYS run at 80 deg C jacket temperature, period. Same with all my previous boats (Cats C32 x2 and Volvo D12 x 4). I've never had a boat where jacket temp fluctuates as you describe.
One of the main differences between the continuous duty engine and it's much higher horsepower cousins is the turbocharger. If you chose to run at higher speeds for the good of the turbo that's a different matter
