colhel
I've just started the Winter work on our Nimbus with a TAMD41A engine.
I may have found the cause of an ongoing issue that has been with the boat since we bought her in August this year where very occasionally, when i first accelerate away there's a kind of rubbing scraping noise, I just throttle back quickly, start again and all is well again. The drive shaft can just be seen through the clamp in the coupling and this is scored quite badly, so I think this could well be the cause, so to rectify I'll need a new shaft and maybe a coupling. I this is the cause is it possible for the shaft to slide out of the coupling, I'm thinking if the shaft is being worn away it could become loose in the coupling, or is there a secondary means the shaft is likely to be secured by? I moved the boat to Weymouth from her home berth in East Cowes so could get a lift out in Portland but ideally I'd like to have lifted and anti fouled in summer back on the Isle of Wight but on the way home I had visions of the shaft dropping out the back.
I've also started work on the cooling system as I've had a couple of impellors go and thanks to our good friend Andy (Andy59 0n here) the seal on the water strainer has been diagnosed as the main culprit, hence it's likely I'll have bits of rubber where don't want them. So I've started to dissmantle and remove the heat exchager and noticed a couple of anomalies, when I drained the gearbox water it was clear, but when I drained the turbo it was red with coolant. I topped up the coolant with plain water before leaving Cowes for Weymouth so the engine was running at a steady 3000 rpm with the temperature gauge reading normal. I'm guessing stray bits of rubber in the system?
Cheers
Col
Cheers
Col
