Timbow
Active Member
I am repairing an old mahog grab rail off the coach roof. I have removed it and it isn't broken in two but cracked and weakened. I am going to get some glue into the crack and cramp it but it needs to be a strong repair - you can't have a grab rail that breaks when you grab it, so I was going to wrap glass mat around the wood and impregnate with epoxy several times to encapsulate the weak section. I have seen it done on spars so the fine mat is invisible and it looks just like thick varnish. I don't think it will give me any difficulty, but...
When I order the mat what exactly am I wanting to ask for? Is it a particular weave or fineness? Is there any complication with matching the mat and resin or applying the two?
Thanks.
Thanks.
