Niander
How much 8mm Anchor chain for a 30' Yacht would the panel recommend?
I want all chain btw
OK if you've an enormous boat which can carry such weight in the bows, or you're blithely unaware of the effects of trimming a boat down by the head.We NEVER ever had less than 100 meters of chain all 8ml plus 30 meter rope.
I have always had all chain. Previous (big) boat had 100m of 16mm. Present fairly heavy displacement 36ft ketch has 65m of 10mm. I can quite understand that a light displacement boat cannot carry anything like that up at the bow, and so are quite correct in having part chain and part nylon warp.
I'm accustomed to the chain coming straight down off the gypsy into the chain locker, and self stowing. How well does that work with warp? Is a quarter of the gypsy in contact with the warp sufficient to pull it in? Does it self stow in the locker?
I don't understand why you want all chain. I've got 30 m of 8 mm chain, and 50 m of 16 mm 3 plat nylon, on a similar sized boat. I wouldn't want any more weight in the bow.....
