volunteer
I have been sailing a 1989 Etap 30 for the past 13 years. Generally speaking I have been extremely happy with it. Apart from the unsinkable aspect (which has to be considered an advantage, else why would anyone buy a liferaft?), the foam does significantly improve the hull's thermal insulation. In my experience water getting into the foam from any leaking fittings does not in fact stay trapped, but gradually leaks out at the lowest point, i.e. at the mast compression post or under a saloon bunk. Tracing leaks is not easy, but not impossible either.
Early models had a quite weak "back stop" to the tiller. Check if it is in place or has sheared off. The later beefed up replacement type is square rather than round section stainless. It's not a huge job to replace.
Hello - new Etap 30 (1986) owner here. Way out in California where there simply aren't many (any?) around. I could really use some help as I'm having some frustration with sourcing deck leaks. And yes, the leaks do arrive right at the compression post base.
I have sealed around the windows and the grab rails - they seem okay. The deck, aside from beneath the deteriorated non-skid, actually looks pretty good - so just not sure where the moisture is arriving from. But, as others have noted, I also get moisture behind the hull-deck joint (which is causing havoc with the teak trim there..
Any advice greatly appreciated!
