I was looking for something else and was sidetracked, as one does, after finding a manufacturer of 7075 alloy nuts and bolts. I am slightly familiar with this quality of alloy as Anchor Right use it for the shank of their alloy Excel which is identical in design to their steel model except for the shank that is a slightly thicker width (to give it a strength comparable to Bis 80).
7075 alloy has a yield strength of 500 MPa vs 690 MPa for Bis 80 and 200 MPa for 316 stainless.
I then wondered - most of the fittings on my mast and boom are stainless and are attached commonly with stainless rivets or stainless bolts tapped into the alloy of the mast and all of these need Duralac, or something similar, to retard galvanic corrosion. Using Duralac is both messy and expensive. My genoa track is alloy but has little plastic inserts between the bolts that hold it to the deck and the track itself. etc
So I then wondered - why are not all the fittings and bolts made from 7075 alloy.
I'm guessing 7075 is expensive but a few alloy bolts and fittings are not going to make much difference to the cost of a stg 100,000 or stg 250,000 yacht.
So what is the catch?
