D
Deleted User YDKXO
Guest
Well RK should get to the bottom of it but 25-26kts is not nearly good enough. Are you sure the engines are definitely revving out to 2500rpm at that speed? Have the rev counters been checked for accuracy?Ive tested using phone, charplottet and logs. All within 1 knot. Have never managed over 29 knots , have the 575 engines. Running 50% fuel, 50% water, empty holding tank and pwc in garage. Had an issue where at wot the enfines would overheat due to exhausts being clogged up, made loads of exhaust noise as well, but thats been resolved now. At 24-25 knots id now still be 95% throttles ......i moved it down to rk marine for its annual service the other week and we maxed at 25-26 against plotter logs and phone.....rk are still trying to work out why. Going to coppercoat the bottem if im going to keep it long term or if im going to upgrade then ill just strip the 5 years of anti foul and anti foul it and polish the prpos and hope that helps.
