kaczman
Hi all,
I have a boat with a mid 90s 5.8L OMC Cobra engine and outdrive on it. I hit some rocks this weekend, and bent up the prop.
I replaced the prop, and inspected it. The outdrive appeared to be good, and ran fine for nearly a 2 hour trip. On the way home, the prop shaft let go.
I had my marina inspect it, and they don't do alot with OMC's. They put it up on dry dock, drained the fluid and saw some metal shavings in it. Im assuming when the prop got bent it bent the whole shaft, and as I used it, it got progressively worse.
The marina is asking if there is a way to inspect the upper, to see if I can just swap the lower unit. Boy are these things expensive. Any suggestions from anyone on this forum? Thanks in advance!
