LadyInBed
42DS - that would be the Day Sailor version then
How do you propose that people learn how to berth unless they are allowed to practice? Especially under the supervision of an instructor?
For what it's worth I've never sailed a modern boat that I thought needed a bow thruster. I've sailed a few that have had them, and I have used them, but I don't think I've yet encountered one that I felt really needed it, i.e couldn't be reliably berthed without it. Every modern boat I've sailed has been predictable and relatively handy under power. Even the OP's example I would class as predictable. Propwalk is not necessarily a bad thing if you know you're getting it...
All of that said.... I wouldn't tell someone that they shouldn't have a bowthruster. I'd normally recommend some instruction before splashing out on one, but if it makes someone more confident in what is (for most cruisers) the most stressful part of the sail, then that has to be a good thing.
I'm sure you are right, and my routine is similar. On the other hand, if Father Christmas gives me one of the new HRs with twin rudders and a single saildrive I just might be persuaded to sink my pride and order a BT, though I'd rather have a steerable prop.I have a big(ish) boat with a shaft prop and I tend to find that I need to give the engine a good chunk of revs for about 5 seconds just to get the boat moving and get some water over the rudder, then knock the engine back and it steers backwards fine.
I find that a good blast of astern gives less walk overall than trying to tickle it along.
I have the same reaction to the prop noise of frantic reversing! For some inexplicable reason, the marina I'm in is happy to let sailing school boats in to "practise berthing". What a nightmare! Yesterday, there was one boat with a group of youngsters on it careering around the marina all day, with many loud reversing noises.
In skilled hands bow thrusters are not required....
And if you are able to do them without a bow thruster - I can't conceive of tighter space and more awkward turns than some Med marinas or quays and none have needed a bow thruster although I can imagine a long keeper would be very limited. It might be worth asking somebody used to park without one to show you how they would do it.There will always be manoeuvres which are only possible with the use of a bow thruster - it will allow you to make tighter turns than the same boat could without it. If you never attempt those manoeuvres, then you never need a bow thruster!
Why have a flushing toilet when a bucket will do the job ?
That's not the point. There are several things on modern boats that I object to on purely aesthetic grounds. Bow thrusters are one, as are stack-pack mains, plumb stems and twin wheels. This is not to say that they may not be useful to less discriminating people, just that I prefer to do without them.A bow thruster is much more effective as its in the right place. Also a steerable prop is another complexity to an already complex saildrive drive train.
A bow thruster can get you out of a sticky situation in a tight marina.
It’s a Sailing boat - why have an engine anyway - in skilled hands easy to sail to the berth!
Did a sea-trial today in a Jeanneau 42DS and was very disappointed by reversing performance.
Lots of prop walk (kicked stern to port) and very poor bite even at high revs e.g. 3000.
Apparently it's a 3-bladed folding Volvo prop.
Any views / experience / ideas?
