stelican
I have a Volvo TAMD31A. with the sea water impeller before the strainer. I fitted a 3 way ball valve to the hose before the sea water pump.
The third inlet/outlet on the valve is fitted with a reducer to take the Gardena type hose fitting.
Normal operation the valve is set to 1 and 2 inlet/outlet open. When I want to fresh water flush engine simply divert flow on valve.
The third position can also be used to run antifreeze through the raw/seawater side of engine or as an emergency bilge pump.
