MapisM
Good choice.
Along the lines of optimizing other jobs while she's on the hard (don't ask me how I know something about that!), I'd definitely have also that shaft checked. Depending on boat age (i.e. if older than a dozen of years or so), it might make sense to check also the other one.
And unless cutlass bearings are still in very good shape, it's a good occasion to replace them too, while shafts are pulled.
Then there's the "usual" stuff, like anodes replacement, thru-hull fittings and seacocks check/replacement if required, antifoul stripping and/or application, shaft seals check...
Just use a bit of man math, and you'll find out that you're saving a lot of money, eventually! :encouragement:
