jwilson
No, take it off and strip and clean it....When you say 'clean th carb' do you mean just running it with the fuel off until it stops ?
If 2 Strokes are "banned" as outboards how come this Generator from Aldi is allowed?
https://www.aldi.co.uk/en/specialbu...st-product-detail-page/ps/p/800w-generator-1/
Thanks, will have a look. As said earlier, I had the o/b professionally serviced last year, do you think a standard service would be likely to include cleaning the carb ?
The bunny-huggers are indeed misguided regarding modern SMALL two-strokes: I am now close to empty on my original one litre bottle of two-stroke oil for a 3.3 Mercury two-stroke that is now coming up to 9 years old. I'd have used significantly more oil if I'd done an oilchange every year on the current 4-stroke version. With two-strokes cleaning the carb thoroughly once a year is the key thing to do: if you do it when the engine gets put away for the winter it should start easily the next spring even on the old fuel.
I have a just-run-in Tohatsu 3.5 2/s in the cellar waiting for the Mercury to die, but no sign of it yet. Bought it new just before they stopped selling them.
Whilst I infinitely prefer a 2-stroke for my tender, I'm afraid you've missed the "bunny-huggers'" point. The unburnt lubricating oil is being injected directly into the water, polluting, far better than emptying an oily bilge. Your 4-stroke oil, on the other hand, is put into a bin for re-cycling and should never get into contact with nature.
An idea of how badly hydrocarbons foul the environment has been brought home to me after 3 nights in Mandraki, Kos - there is a 80mm wide black, impermeable deposit all the way around my hull. Just imagine having that deposited on your gills...
A free Boot Top!after 3 nights in Mandraki, Kos - there is a 80mm wide black, impermeable deposit all the way around my hull.
Are 4-strokes less prone to problems with fuel clogging the carburetor than 2-strokes? I am at my wits end because I use my outboard so infrequently I really don't want to have to drain the tank after each use. As I say I never had this problem with my old engine. I am not sure if it is the new engine at fault because it might just be a coincidence I believe we now have a proportion of ethanol in our fuel and this is the main cause of the problem.
Drain the carburettor every time you finish using it. Just run the engine and turn off the fuel tap. When it stops, usually some 10s of seconds perhaps a minute or so, the carb float bowl is empty so no fuel gelding or corroding rubber parts. It really is very little hassle. Empty fuel at the end of the season and start with fresh fuel in the spring. That's the way to a reliable 2T
That's not so easy on my 2stroke - it's been got no neutral.
Orwellian "Four strokes good, two strokes bad" decree.
I've heard this before. I have had a Yam 4HP 4 stroke, a Honda 5 HP and a couple of Tohatsu/Mariners. A long steady pull is the trick. Not the short yank that 2 strokes seem to prefer.I bought a new Yamaha 4 stroke (still don't know why i did that) as it was a pain to start, then I realised the 2 stroke, 2 cylinder was firing twice per rev, the Yamaha 4 stroke was firing 0.5 times per rev, no wonder it was harder to start!
Same with motorcycles (well, with a long steady kick rather than a pull). And they never break your wrist (although they might your ankle).
