hamish24
New Member
Hi, i have a 96 4.3lt V6 mercruiser. recently had carb rebuilt as it had a lot of **** in it from sitting over winter.. ever since put back on boat it has had a problem when running engine between 3900 & 4600rpm, over and below these rpm boats runs great. But in this range it has like a popping/backfire sound coming up through carb?? im sure its not a backfire but it sounds similiar and it runs a bit rough.
we have timed the engine at these revs and has not fixed it, put new plugs in it still no better.
Carb man has had another look and is adament that it is all set up exactly right and is working perfectly.
any suggestions as to what my problem could be?? it has the thunderbolt ignition....
am getting really frustrated with this engine as we have had all sorts of problems in the past and finally got it going good last season and then this came along.....
thanks in advance
thanks in advance
