prv
Hi,
I'm going to be removing and overhauling my engine this winter, and I want to take the opportunity to add some "unstoppability" features (dual changeover fuel filters being the classic example).
One of the things I'd like to do is make it possible to "rod out" the intake seacock in case anything gets stuck in it. The boat will be on a mud berth, which seems to provide a certain potential for debris, plus there's always the rogue carrier bag to watch out for. Fortunately, the arrangement of the boat is such that the seacock is in a relatively spacious location under the cockpit, with an access hatch in the sole directly above it. What I was thinking of doing was replacing the current gate valve with a three-port ball valve. One arm of the T would screw onto the skin fitting, while the engine intake would be on the side arm. The remaining arm, facing upwards, would have an 18" length of fairly lightweight transparent tubing.
Normally, the valve would be set to connect the intake arm to the engine. In the event of blockage, though, the transparent tube would be brought up through the hatch, bringing it above the waterline. The valve would then be turned (after undoing some kind of security device to prevent accidental switching to this mode) to connect the transparent tube in-line with the skin fitting. A straight rod clipped nearby for the purpose could then be shoved down the tube and out through the skin fitting. I might well also add a hose barb and screwed blanking fitting to the open end of the tube, as a second safety cutout.
The only flaw in this plan (unless you guys care to suggest others
) is that I cannot find anyone selling three-way ball valves in a material that I would want to use on a skin fitting. Any pointers?
