Vladis
Active Member
In my Beneteau Oceanis 40 I have 3 black wires, each one
connecting to the anode of a rectifier diode and the 3
cathodes joined together. From the cathodes join goes another single
black wire to one of the contacts of a relay. The other contact
of the relay is connected to ground. The relay is activated with a
signal coming from the alternator. As far as I know this scheme
is used in many Beneteaus and Jeanneaus. Returning to the
3 black wires, one comes from the anchor winch switch and the
other two come from the engine exhausting fans.
The reason is to guarantee that both the anchor winch and the fans
only work when the engine (alternator) is running. As I have
a 100A reset-able switch breaker for the anchor winch I removed
the corresponding black wire (together with its diode) from the
relay and connected it directly to ground.
My question is that I do not understand the purpose of these diodes.
I would be grateful if anyone could give me an explanation!
